help with car no start
k my 95 accord will not start the fuel pump wont turn on threw ecu signal , if i run a hot wire(12volt) to fuel pump it primes but wont come on..I also replaced main relay with a brand new one... someone help
The next thing I would check is the ignition switch.
http://techauto.awardspace.com/ignit...ch.html#Repair
well the stater turns over an its getting spark. i read over the bad ignition switch symptoms ... i went to my local junk yard an picked up a used non vtec ecu hope to see if that will get it to start then its my ignition switch
cummins327
Dec 23, 2011 10:26 PM
slow hatch
Apr 19, 2004 10:00 AM
