can I run a 90 teg ecu?
Old Oct 9, 2002 | 04:54 PM
SuperJay's Avatar
Default can I run a 90 teg ecu?
Been asked a million times I'm sure, right now I'm runnin a 89teg ecu and was wonderin if I do a b18a swqp if I could just swap the ecu with no wiring changes. thanx (PS. I did do a search and found nothing).
Old Oct 9, 2002 | 06:08 PM
MrTodd's Avatar
Default Re: can I run a 90 teg ecu? (SuperJay)
I think the LS ('90-91 Teg) ECU is plug 'n play. It's called a PR4? Not sure, but it must be a manual 5 spd.
Old Oct 9, 2002 | 06:38 PM
S13 slide's Avatar
Default Re: can I run a 90 teg ecu? (MrTodd)
yeah im running a obd0 b18b in my 91 hatch and running a 91 ls ecu. no problems
Old Oct 10, 2002 | 05:45 PM
SuperJay's Avatar
Default Re: can I run a 90 teg ecu? (S13 slide)
slick, thanx for the info
Old Oct 10, 2002 | 10:21 PM
spettinger's Avatar
Default Re: can I run a 90 teg ecu? (chrisonepointsix)
if you need an LS ecu, i have one, from a 1990. stock. i would like to get about $80 shipped.
Davanca
Apr 16, 2005 06:25 PM
stevescivic
Feb 4, 2005 05:38 PM
86CRXSi
Jun 17, 2002 02:01 AM
Project_Integra
Apr 9, 2002 10:14 PM
