Which cat/test pipe to run on 99 civic si with Jdm ITR header
Old Feb 14, 2012 | 04:25 PM
Tuner Eddy's Avatar
Default Which cat/test pipe to run on 99 civic si with Jdm ITR header
Hey guys,
I'm picking up a 4-2-1 Jdm ITR header from a 96-97 ITR. I'm currently running a dc sports 4-1 ITR header with an oem integra cat, but the header is cracked so I found a replacement. Is the oem integra cat the proper cat for this header? I think my answer is obvious, but I read a few places that the 96-97 ITR header is shorter.
Thanks.
Old Feb 14, 2012 | 08:32 PM
nin478's Avatar
Default Re: Which cat/test pipe to run on 99 civic si with Jdm ITR header
You should be fine, I have a jdm itr header on my ej hatch and it fit fine. If you need a test pipe I have a skunk2 one that fits the 96-00 model civics and I'm in ga so we may be able to work something out if you need it. Pm me if you need it.
Old Feb 14, 2012 | 08:35 PM
Texas4door's Avatar
Keep the cat if your emissions laws require it (or have some pipe welded on so the cat'll fit properly)
Use a test pipe if they don't
Simple ^^
slateEKsi
Jul 26, 2010 04:06 PM
blackhbkid
Feb 7, 2009 09:44 PM
2ndgent3g
Apr 9, 2007 02:50 PM
SirEm1
Oct 6, 2004 11:57 AM
