is it ok to run jun cams with skunk2 retainer, valve springs?
or is it better to run all jun's??
how many stage is there in juns?(cams) in japanese site i think there is only 2 stages~
so if i get jun cams and use skunk2 retainer, valve springs is it safe?
thank you~
thank you~
Jun has 3 stages of cams.
You can run the skunk components, if you want. I would keep it all JUN, but the JUN Ti. Ret. are very expensive I have heard they dont last too long. But wait for the pros
STAGE 1
CAMSHAFT 1 SET
RACING VALVE SPRING 1 SET
STAGE 2
CAMSHAFT 1 SET
TITANIUM VALVE RETAINER 1 SET
stage 1 for 120,000 yen =973.478 USD =1,554.02 CAD
stage 2 for 162,000 yen =1,314.04 USD =2,097.67 CAD
are they good deal or what?
CAMSHAFT 1 SET
STAGE 2
CAMSHAFT 1 SET
those arent the cam stages. Those are package stages..As you can tell the Stage 1 does not include Ti. Ret. but the Stage 2 does. JUN has 3 stages of cams. Its all up to you if its worth it or not. You will need more compression to get full potenial out of these cams.
http://www.junauto.co.jp/products/cy.../index.html?en
me
