2000 Accord auto transmission CEL codes
Hello,
A friend of mine has had her 00 Accord auto for about 30k+ miles. The car is almot hitting the 200k miles. She recently got the below CEL codes regarding the auto tranny.
What would be the best route to fix her problem? Is it worth it to even fix it? Thanks.
41-01 incorrect gear ratio
46-01 clutch pressure malfunction
IIRC on the end cover of the transmission there is an elctrical switch mounted. This indicates to the PCM what gear has been selected. If it is out of adjustment or has been damaged it could be sending conflicting inputs to the PCM.
Ryan2005accord
May 7, 2015 05:15 AM
AmericanPie
Transmission & Drivetrain
Jan 14, 2010 10:24 AM
