Tachometer on cluster stops working?
Old Feb 13, 2012 | 07:53 PM
5speeder's Avatar
Default Tachometer on cluster stops working?
My tachometer will work fine but if I drive it for a while it will stop working and the needle will drop down to zero. If I shut off car right away and turn it back on right away it will work again for a while and just repeat. Any ideas? Need help maybe hook up tachometer on side and see if it works?
Old Feb 13, 2012 | 07:55 PM
5speeder's Avatar
Default Re: Tachometer on cluster stops working?
Originally Posted by 5speeder
My tachometer will work fine but if I drive it for a while it will stop working and the needle will drop down to zero. If I shut off car right away and turn it back on right away it will work again for a while and just repeat. Any ideas? Need help!!! maybe hook up tachometer on side and see if it works? Or bad wiring, distributor, cluster?
Old Feb 14, 2012 | 07:54 AM
5speeder's Avatar
any ideas guys? i would assume if my tachometer on my cluster is bad that it wouldnt be working at all then? but it works everytime i start it up.
Old Feb 15, 2012 | 01:55 PM
5speeder's Avatar
Help anyone?
Old Feb 19, 2012 | 12:17 PM
5speeder's Avatar
finally tried to floor the car, tachometer stops reading at about 3000 rpm, but nothing wrong with motor, its still going but i have no idea after 3000rpm, no CEL lights either, is this something with the tachometer itself? maybe distributor? its a new distributor.
Old Feb 20, 2012 | 08:39 AM
CRX-Kid11's Avatar
check wiring going to ignitor, usally the tach wire is blue, make sure nothings corroded or loose, but it may just be a faulty cluster, doubt its ignitor or distributor pickups since its new, easiest way is to try and swap clusters with some one to test, only takes a few mintues to remove
Old Feb 21, 2012 | 02:37 PM
10psiLsEf2's Avatar
loose vss connection on the tranny?>
Old Feb 21, 2012 | 03:11 PM
5speeder's Avatar
it will read everytime the rpms are below 3000 so when im casually driving it and shift gears it will be fine, but when i free rev it or floor it in gear the tach will just stop at 3000, i doubt its a loose connection, haha ebay richporter distributor, what you guys think?
Old Feb 21, 2012 | 06:16 PM
civicjunkie17's Avatar
The Vehicle Speed Sensor has nothing to do with this.
Your distributor is what sends signals to the tachometer. As stated early test your ignitor inside the distributor and especially check the connections on the three wires. Awhile back my tach was giving me problems when I would put +80% load on the car the tachometer would start going nuts. What I did is sanded and cleaned the terminals and put a dab of conductive grease on it to assure a good connection.
Old Feb 22, 2012 | 07:01 AM
5speeder's Avatar
how do i test the ignitor? and i would assume if i had a faulty cluster then the tach wouldnt read at all?
Jesse8859
Oct 25, 2015 04:15 PM
B_Swapped93
Jul 18, 2013 03:56 AM
blackdx1
Jan 25, 2011 04:47 PM
Dc295kid
Mar 27, 2009 07:32 AM
civiccpedx
May 18, 2007 06:56 PM
