Serious Problem. no Spark! need car up asap.
Old Feb 13, 2012 | 05:16 PM
96b18c-r's Avatar
Default Serious Problem. no Spark! need car up asap.
Okay,
I have 98 Civic Dx Hatch. Equipped with a 95 Gsr. Car has been running perfectly fine. I drove it all day today.
-Motor is obd1.
-car is obd2.
-harness obd2.
-jumper harness - p28 ecu.
I started my car to go back out today. Turned around to grab my phone, when i looked back at my car it turned off like someone turned the key off. Like a fuse blew almost. The car now has no spark. I Called my friend, who came over.. We put his dizzy on my car. his ecu. his main relay. I've tried everything I can think of.. The car has no spark but does have fuel pump working and everything else is normal.
I did wash the car about an hour or two before this but it drove home fine. So i don't think there is water in anything or something like that. This is my way to get to work etc.. I need to figure this out. Please help.
Old Feb 14, 2012 | 07:27 AM
96b18c-r's Avatar
Default Re: Serious Problem. no Spark! need car up asap.
bump. dying for some feedback
Old Feb 14, 2012 | 07:38 AM
Civic2Fast's Avatar
make absolute certain that there's no water on your sparks plugs... since you swapped dizzy's you ruled out a wet cap... even the slightest condensation can cause weak or no spark... if you washed the engine make sure there's no water in your distributor connector...
Old Feb 14, 2012 | 07:42 AM
grumblemarc's Avatar
The Grumpiest
No Start Diagnosis Basics
Old Feb 14, 2012 | 07:50 AM
Former User's Avatar
Does the fuel pump prime?
Did the timing belt snap?
Any CEL codes?
Old Feb 15, 2012 | 06:31 AM
96b18c-r's Avatar
no cel, no timing problem, fuel pump is working and getting fuel to cylinders. I have no spark. I have now replaced the (motor harness, dizzy, ignition, main relay, checked all fuses, ecu..)
I am now completely lost on what to do. It makes no since. I did not wash the engine bay just the Car. Most i have ever used in the bay is a quick detail spray but not on plugs or wires, just on the bay bcuz' its open and tucked.
Old Feb 15, 2012 | 08:10 AM
LSVTAK_EK's Avatar
You may hear the pump working but it may be weak, I've had that happen before when I thought that the pump was working but in fact the pressure wasnt quite enough!
Just a thought
Chris Gaudreau
Apr 9, 2018 06:37 AM
vtechachey
Dec 25, 2009 03:18 PM
SiShane
Aug 31, 2004 07:50 PM
