steering conversion!
Old Feb 13, 2012 | 03:48 PM
EF-DAWG's Avatar
Default steering conversion!
okay i have a 89 ef sedan. mine dose not have power steering. from what year can i get all the accessories to convert it! ??
Old Feb 13, 2012 | 06:48 PM
dylaxiin's Avatar
Default Re: steering conversion!
are you not strong enough to turn the wheel?!
Old Feb 13, 2012 | 06:51 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
All sedans had power steering... look around under the hood (unless someone converted it to manual - I doubt it). If they did, then I am SURE you could find an "enthusiast" that would want to trade you!
You can pull the parts off of any '88-91 Civic.
Old Feb 14, 2012 | 08:39 AM
DCRB's Avatar
dx sedan models did not receive power steering.
o/p your best bet is to stick w sedan parts, although everything is interchangeable.
you will need the rear sub frame, the power steering rack, new inner and outer tie rods (why not? they are a wear item after all), the hard lines, pump, reservoir, p/s cooler, power steering mounting bracket, and the crank pulley for the swap.
i personally wouldn't do it, those that have swapped to power steering hated it and swapped back to a manual rack
Old Feb 14, 2012 | 08:55 AM
91 EF DX's Avatar
leave it manual, more hp and less things to worry about leaking
Old Feb 14, 2012 | 09:17 AM
DO IT ON ALL FOURS
Interesting - I have seen hundreds of sedan DX's and have never once seen one without power steering from the factory. Power steering must have been optional?
Old Feb 14, 2012 | 09:31 AM
BLU CIVIC's Avatar
Track Advocate
I believe it was. like every STD hatch i've owned has had a/c, i thought it was standard
Old Feb 14, 2012 | 02:14 PM
DCRB's Avatar
yeah a friend of mine has a bone stock 91 dx sedan, no power options besides aftermarket added ac and of course power seat belts. same as the red dx i got my mt conversion from
Old Feb 14, 2012 | 05:22 PM
EF-DAWG's Avatar
yeah mine is the dx..well im doing all this power steering because my rack and pinion got messed up because of the force..so if ama have to buy a whole rackn and pinion why not do the conversion of a powersteering..hope you guys feel me
Old Feb 14, 2012 | 05:31 PM
jdmef69's Avatar
Or you could lift some weights so it's easy for you to turn it jk jk go to junkyard for the brackets and such. Then go to a parts store and spend a bunch of money on power steering stuff.
Old Feb 14, 2012 | 07:30 PM
~sp33~'s Avatar
EFB055
I hope you're not implying that having a car with power steering would somehow put less stress on the mechanical components.
Anything that is easier for you is harder for the mechanical components.
b16bri
Suspension & Brakes
Jan 12, 2012 06:05 PM
SC_HOBD_1816
12
Feb 5, 2009 05:49 PM
ahron
Jul 18, 2007 03:50 PM
grant_x
May 26, 2006 04:32 AM
