Code 43
Old Feb 13, 2012 | 03:28 PM
robertosanchez's Avatar
Default Code 43
What's up HT , I'm having a little bit of trouble here I can't get this danm code to go away it's a code 43 which comes up as FUEL SUPPLY , an I think for the 02sensor it's a 90 civic si with a complete d16z6 swap with obd1 conversion an running with a p28. The things I have replaced already I went through 2 o2sensors I also took my 62mm edelbrock throttle body an went with stock took my cam gear an put the stock 1 back on an my harmonic balancer an replaced with the stock. Now the reason why I took all that off is because I was having a problem with the timing ! I put both the timing marks on the cam an the balancer to there proper marks but when I would go to set the timing ignition (using a timing light of course ) it would be way off I would have to advance my distributor all the way an I still wouldn't be able to line up the red center mark of the 3 marks ? What can cause this an what can cause that code 43 any help will greatly be appreciated thanks
Old Feb 13, 2012 | 03:48 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Code 43
O2 sensor
Fuel filter
Fuel pressure regulator
Injectors, distributor, spark plugs, plug wires, and anything else that delivers fuel or ignites fuel that doesn't have a sensor of it's own.
Old Feb 13, 2012 | 04:31 PM
Default Re: Code 43
Ok so the oxygen sensor is out of the question then given that I went through 2 of them so it can't be that fuel filter I do have a aftermarket one on there it's a JDM PASSWORD fuel filter maybe that can be it but I just bought it before I put the motor in an it's only been in for like a month (running) as far as the distributor it's brand new I just bought it yesterday with rotor didn't buy the cap maybe I can start there the plugs are pretty much new too but I was having a problem with the timing an it running really rich don't know if that can cause the plugs an the wires to go bad FPR is a vision adjustable an it holds pressure I have it set at like 35 an at WOT it hits 40 injectors I just changed cuz I was running the low impedance so I got the ones that belong to that motor which are high impedance an got rid of the resistor box . What causes the check engine light to come on I leak or something
Old Feb 13, 2012 | 05:22 PM
Default Re: Code 43
Any other replys ?
Old Feb 13, 2012 | 07:15 PM
ef yu's Avatar
Default Re: Code 43
Originally Posted by 4drEF
O2 sensor
Fuel filter
pretty much this.
that code can be a PITA. good luck
Old Feb 14, 2012 | 05:14 AM
Default Re: Code 43
do you guys think it can be the charcoal canister not being hooked up !
Old Feb 14, 2012 | 07:58 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Code 43
Aftermarket FPRs are a usual problem. Try a stock one.
Old Feb 16, 2012 | 03:55 AM
Default Re: Code 43
ok thanks for the response ill try that today .
blasterman87
22
Sep 25, 2009 07:50 AM
nogutsnoglory77
Jun 28, 2009 09:49 AM
88 rex
Dec 14, 2006 11:16 PM
JCCOOL43
Nov 7, 2006 05:32 PM
