Suspension & Brakes Theory, alignment, spring rates....
front lower control arm
Old Feb 13, 2012 | 08:33 AM
SR20S13's Avatar
Default front lower control arm
so I just had all my bushings replaced with hardrace bushings along with the compliance bushing. Now when i'm trying to install it the bolts don't line up when its attached to the LCA but they do line up when its off, what is the order I should install the LCA, should i bolt in the compliance bushing then put the bolt in for LCA its self (the one that attached to the subframe) this is for a 95 civic hatchback
Old Feb 13, 2012 | 08:45 AM
GagnarTheUnruly's Avatar
Default Re: front lower control arm
You won't be able to reach the compliance bushing bolt to tighten it if you put it on the subframe before you attach it to the LCA. This is the order I remember using:
-Assemble the LCA and compliance bushing
-Mount the inner LCA bolt to the subframe
-Mount the compliance bushing to the subframe
-Mount the outer end of the LCA to the knucke
-Connect the shock fork to the LCA
Make sure you install the compliance bushing correctly with the washers in the correct position and orientation and the compliance bushing correctly oriented.
Old Feb 13, 2012 | 09:49 AM
SR20S13's Avatar
what is the correct orientation and the order for the washers since the honda shop manual says nothing about it, i've read it like 5 times just to make sure haha
Old Feb 13, 2012 | 10:04 AM
SR20S13's Avatar
never mind on the washers i found that both need to have the FT stamped facing the front
brewerkz
Jul 6, 2016 03:23 PM
jdmsupreme2132
Suspension & Brakes
Nov 6, 2009 03:19 PM
Coreymdean
May 25, 2008 09:33 PM
navin
Mar 30, 2007 10:12 AM
E-AT_me
Apr 16, 2003 04:37 PM
