2006 Accord Brake lights problem
My brake lights are not coming on when i press the brakes. I have checked all fuses, and I dont see one burnt out. Funny thing is the tail brake lights come on when i turn on, or turn off my factory alarm with the remote. However the 3rd spoiler light does not light up at all. Is it possible the third brake light is burnt out, and causing the others not to work, in normal mode?
I had both brake lights go bad within two weeks. Finally got around to checking, and it was the bulbs. I believe if the brake light switch goes bad, you should not be able to shift out of P without using the key to override (at least that is true for the '03's)
Its not the brake light switch. I just changed it out, and its doing the same thing. My 3rd brake light nor my rear brake lights are not cutting on when i press the brakes.
I had an issue with my accord a few years back where my lights were doing the same thing but it was my headlights. Turned out, the bulb was to powerful and it heated up my wires to the point of shortage. Maybe have a look at that.
disboiflaco
Mar 14, 2011 05:45 PM
microjubei
Sep 23, 2009 07:30 AM
