How do I remove the front bumper of my 91 crx?
I know theres two screws on each side in the tire well. Three across the front and then one on each side under the corner lights. How do I get to the screws underneath the corner lights?
Pictures or diagrams would be great, thanks for any help. I did a quick search but didnt find anything for crx's.
Or even if someone explained how to remove the corner lights that would be great. Also are those the only screws holding the bumper in place?
If you open the hood you'll see a screw in between the corner light and the headlight. Take that screw out and the corner light will come off by pulling it toward the front of the car.
remove your bumper side signals and there two screws in there..than in the bottom should be two more and inside by the tire theres two more..should come out easily..
remove 2 screws on both ends of bumper in wheel well area
remove both bumper lights, 2 bolts behind each bumper light (needs long extension)
2 10mm bolts underneath front bumper one left and one right
