Ef B16A Build
So Ive been doing a little Research and I know there are a ton of forums and guides and stuff but I have a Few questions of my own just need some advice and a little help. Ill just go with the specs for now.
1990 honda civic hatch ef/dx
5spd
on dash 264xxx miles
engine i guess was supposed to be d15b1/b2
has the d15b7 it is F/I with Dual port
what I want to do/looked into
b16a 1st gen
budget:500-1000$$
notes:read somewhere that if car is dual port then it has to be converted to mpfi.
I think Ive covered all my questions but anything you guys can give me would be great
5spd
b16a 1st gen
budget:500-1000$$
ill look around on how to do that but should the b16 just drop right in?
whats a list of stuff for my civic that I would need?
90-91 integra axels?
civic SiR axels that stuff
what works best in the long run.
use OEM obd0 engine harness from the car
wire dpfi to mpfi
http://ef-honda.com/ben/EFwiring.php
http://www.fourthgenhatch.com/mpfi.html
http://ef-honda.com/ben/EFswapguide.html
no, it's not plug and play. I'm fixing a wiring mess in a b16 ef right now. do it right and dont cut random wires. make sure you solder and heat shrink and do not use butt connectors.
wire dpfi to mpfi
Hasport Mounts and Shift Linkage:
http://hasport.com/store/index.php/m...series-ef.html
http://hasport.com/store/index.php/a...e/efblink.html
The Hasport mounts don't come with a ef b-series rear mount (atleast mine didn't), so try to find on amazon or ebay.
wire dpfi to mpfi
wire dpfi to mpfi
whats the better choice and why?
trampuscool
Dec 20, 2010 08:16 AM
Dillon91Teg
Dec 3, 2006 10:47 PM
