1995 honda accord tire wear HELP!
I need help! I have a 1995 Accord 4 door. I have horrible wear problems on my rear tires, burning through tires and am over it. I have read a few posts and stuff online and it seems like its camber, but both sides of my tires wear bad! I had a blow out saturday night at 70mph and it sucked, so i need to get this fixed ASAP. It has sprint lowering kit on it (installed before my ownership). Tires just recently started wearing bad like this as of november ish. What causes this wear on inside and outside of tires? inflation was where it should be. Is it Camber or something else? Any help would greatly be appreciated.
did you check your A arm bushings ?? might be the cause. usually in and out side wear is from under inflation.... but you said it was ok so i would look at the bushings.
pressure on tire that did not blow was 38.8 and door jam says 34 and tire says 45 max. when I had new tires put on in october they said they couldnt check allignment because of an issue. Ill try and see what they said it was. could bad struts in the rear cause this wear?
wrtwdtbbfl05
Feb 17, 2012 03:07 AM
lamboextreme
Jun 17, 2007 03:31 PM
SHystrdyGSRtdy
Aug 12, 2006 09:22 PM
