'95 CX Control arm Bushing question
Old Feb 12, 2012 | 01:50 PM
MacGSX's Avatar
Default '95 CX Control arm Bushing question
I just bought this car and for the first time today had it up on jack stands to rotate the tires... When I checked the front wheels for any play I found the front passenger side wheel had a lot. I can visually see that it is the bushing on the lower control arm that is bad. My question is, for the bushing circled in yellow, is that a press in bushing? I looked around the autozone site and can't even seem to find the bushing I would need. I wan't to figure out what is needed before taking anything apart since I daily drive this thing.
Thanks.
Jordan
Old Feb 12, 2012 | 02:01 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: '95 CX Control arm Bushing question
You can buy a front LCA Energy Suspension bushing kit that DOES NOT require a bench press for installation.
http://www.jegs.com/i/Energy-Suspens...rentProductId=
Old Feb 12, 2012 | 02:05 PM
MacGSX's Avatar
But does the old one need to be pressed out?
Edit- Thanks for that link by the way!
Old Feb 12, 2012 | 02:06 PM
94EG8's Avatar
Seagull Management
They're pressed in. You don't need an actual press to install them though, I've done lots of them with a 5" bench vise and a hammer.
To remove the old one without a pressed the easiest thing to do is remove the center part (if it's in really bad shape grab the metal center tube in the vice and twist the arm until it breaks free) otherwise burn the rubber out with a torch. Then hacksaw through the outer metal ring in 2 places about a 1/4 inch apart and knock the rest out with a hammer and chisel.
Also personally I'd go with OEM or hardrace bushings.
Old Feb 12, 2012 | 07:42 PM
MacGSX's Avatar
Ok guys, last question then... I feel like a total noob but Honda's are so foreign to me I'm just trying to avoid any mistakes.
I have three options for lower control arm bushings... Lower outer/ lower inner/ lower at wishbone... Which one is the one circled? I kinda it's the wishbone bushing but I'd like to verify that... These are what I'm looking at...
http://www.autozone.com/autozone/par...74_77429_5285_
http://www.autozone.com/autozone/par...335204_0_2332_
http://www.autozone.com/autozone/par...335214_0_2333_
And I am a huge advocate for using OEM parts but this is my 800 dollar beater back and forth to work, I'm trying to stay as budget as possivle, so duralast will do fine
Jordan
Old Feb 13, 2012 | 05:49 AM
MacGSX's Avatar
Anyone? All 3 arent stocked at my local parts store and need to be ordered. If anyone knows it would be a big help. Thanks.
Old Feb 13, 2012 | 06:37 AM
94EG8's Avatar
Seagull Management
It should be the inner one.
Old Feb 13, 2012 | 07:00 AM
MacGSX's Avatar
Thank you sir.
Old Feb 13, 2012 | 08:37 AM
NVturbo's Avatar
O.G. triple O.G.
Just get the kit I linked you to. It's only $50 and it is for both L/R.
Old Feb 13, 2012 | 11:36 AM
MacGSX's Avatar
That would be great, but with a 10 day back order and another 2-3 days in shipping time thatS longer than I want to drive this thing in its current condition. The bushing in completely shot allowing about an inch of play in the wheel. I will most likely get a kit like that and replace everything down the road for good measure.
Old Feb 13, 2012 | 11:44 AM
fasterthanueg's Avatar
You can also just get a used control ARM from the junk yard or find someone parting out a civic for like $15
Old Feb 13, 2012 | 11:46 AM
NVturbo's Avatar
O.G. triple O.G.
There are plenty of other places (online) that carry them in stock.
Old Feb 13, 2012 | 01:16 PM
98civdx's Avatar
Master Detailer
I've always bought directly from ES.
http://www.energysuspensionparts.com...prod=16%2E3105
Shipping is fast too!
EDIT- If one bushings is that tore up, check them all while your under there. I am willing to bet that bushing isn't the only one.
riiko155
Aug 13, 2010 05:58 AM
clarkekent13
Suspension & Brakes
Oct 7, 2005 06:48 AM
CRAZYEG9
Sep 14, 2004 03:32 AM
mikecel79
Jun 3, 2002 04:53 PM
