EG passenger turn signal on constantly. Not flashing
Old Feb 12, 2012 | 12:27 PM
Bikes&Bowties's Avatar
Default EG passenger turn signal on constantly. Not flashing
So on my 92 eg the turn signal and front running light (both filaments in the bulb) are constantly on even when the car is off. I have pulled all the fuses relating to the lights and the hazard switch and light switch and nothing makes it turn off. Hazards work for about 3 flashes and then stay on constantly and the driver turn signal works fine while the passenger turn signal doesn't flash at all. I have never came across a problem like this and searching google or here only leads me to different problem threads. It would be very helpful if someone could post up some wiring diagrams. Thank you!
Old Feb 12, 2012 | 04:42 PM
Default Re: EG passenger turn signal on constantly. Not flashing
Well I have it traced down to the "option" fuse under the hood. Where's that wire go?
Wendell Hankins
Lighting
Aug 26, 2015 03:32 PM
smmagoo20
Nov 6, 2012 07:59 PM
JConto
Lighting
Aug 31, 2009 03:30 PM
he_who_corrupts
Jun 3, 2007 08:55 PM
