Pic Request
Old Feb 12, 2012 | 10:03 AM
Earthworm Jim's Avatar
Default Pic Request
Accord 1994-1997 on 15 inch rims. Lowered perferably.
Old Feb 12, 2012 | 10:42 AM
dglassmyer's Avatar
Default Re: Pic Request
Heres mine, not lowered though, and yes I realize the wheels face backward.
Old Feb 12, 2012 | 10:56 AM
Thanks man. What size tires are you running?
Old Feb 12, 2012 | 11:04 AM
dglassmyer's Avatar
205/60/15
Old Feb 12, 2012 | 11:21 AM
205/60/15
Wanted to pic up some RPF1's was unsure about the size, now I'm sure I can run 16's on 50's. Nice, thanks for the quick response man.
Old Feb 12, 2012 | 11:47 AM
dglassmyer's Avatar
No prob, is this kinda what your thinkin bout?
http://hondamarketplace.com/showthread.php?t=2994120
Old Feb 12, 2012 | 12:06 PM
Same rims but with more tire.
Old Feb 12, 2012 | 02:08 PM
perfecteverytime's Avatar
I'm running 16" RPF1's with 205/50's. Here are pics for your reference.
Old Feb 12, 2012 | 02:14 PM
djkurious's Avatar
195-60-15 on FF coilovers Type 1
Old Feb 12, 2012 | 07:35 PM
Clean. Any rubbing issues?
Thanks for the picture.
Old Feb 12, 2012 | 11:02 PM
I thought about 15's in order to be able to run these: http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Feb 12, 2012 | 11:06 PM
F'n 4:114
Old Feb 13, 2012 | 05:03 AM
No rubbing with normal driving. I've only had minimal rubbing when turning close to full lock over larger bumps, etc.
Old Feb 13, 2012 | 12:57 PM
Nice, what are you lowered on? Did you get a camber kit?
Old Feb 13, 2012 | 01:29 PM
Lowered on function&form type 1's, with no camber kit.
Old Feb 13, 2012 | 01:31 PM
J/w, how do you have so much wheel gap with F&F coil overs? I mean no offense by this, I'm just curious, because on mine, without adjusting the preload, I can't go much higher in the back.
Old Feb 13, 2012 | 02:46 PM
I want to deep dish my Accord, now that I found SSR rims that would allow me to do that and they're pretty light. I still want to run 16's but I want 16x8's. What do you think the offset shoudl be? Here are the rims.
http://www.ssr-wheels.com/wheels/ms1r_151617.asp
Old Feb 14, 2012 | 06:28 AM
It depends on what look/function you're going for. I don't know much about offsets. If you want to find out if they'll fit, look for pics of other people using similar sizes, or find an offset calculator.
Old Feb 14, 2012 | 09:03 AM
It's my DD but I don't like that gay *** camber. I found an offset calculator though.
Old Feb 14, 2012 | 10:13 AM
That's good. You will have negative camber if you lower it. The angle changes depending on height alteration of course. A certain degree is tolerable, provided you have a good alignment.
Old Feb 16, 2012 | 04:41 PM
Do you know the offset of the XXR 2's?
Old Feb 16, 2012 | 05:50 PM
no, sorry
CivSteez
May 25, 2009 01:26 PM
AccordCD5
Mar 5, 2008 04:57 PM
mugenspoongsr
Nov 15, 2005 07:47 PM
crdcz03
Nov 28, 2004 06:49 PM
