4g JDM Headlight installation help
Old Oct 9, 2002 | 03:11 PM
ZoNe_HKS's Avatar
Default 4g JDM Headlight installation help
is there a convertor i can buy so one end connect to 9006 and one end connect to H4, or if not is there a socket i can buy so i can connect the H4, and then wire it. Where can i go to get the cheapest parts for it, help plz
Old Oct 9, 2002 | 03:25 PM
armharm's Avatar
Default Re: 4g JDM Headlight installation help (PDP_HKS)
there used to be an article on HP.com.... i wonder if anyone has that?
Old Oct 9, 2002 | 05:42 PM
PrecisionH23a's Avatar
Default Re: 4g JDM Headlight installation help (armharm)
i do
http://people.clemson.edu/~averma/ho.../JDMwiring.htm
and
Old Oct 9, 2002 | 11:03 PM
armharm's Avatar
Default Re: 4g JDM Headlight installation help (GudeH23a)
what if you really want to use H4 bulbs and want fog lights?
Old Oct 10, 2002 | 07:22 AM
satan_srv's Avatar
http://www.preludeonline.com/showthr...threadid=88235 as I pointed out here...the real JDM way to wire the bulbs is the H4s for low only, and the H1s as highs, just like USDM wiring.
You can buy H4/H1 harnesses at a Pep Boys or whatever, I got them here at Canadian Tire, cost a couple bucks. Wire the lowbeam like Gude did above except use an H4 harness. It's easy.
Old Oct 15, 2002 | 05:38 PM
Bklyn TSi's Avatar
Banned
Default Re: 4g JDM Headlight installation help (satan_srv)
haha i am desperate now!!!, i checked pepboys didnt have the h4 harness, so i went out there and ordered some h4 wire harness kit that people use to improve power supply, **** is like 25+shipping 35 bucks totalY!!! whatever like i said, i am desperate because i put the headlight on without wiring so i cant drive at NIGHT!!!! and when i get the h4 harness, my friend is going to wire it so highbeam and lowbeam can both work and h1 will be a foglight, thanks for the info guys! btw the prelude reenforcement is ******* hard to take out, like no other car out there! i had 9 cars b4 this, never had i had this much trouble taking something off!!
Old Oct 15, 2002 | 05:40 PM
Bklyn TSi's Avatar
Banned
Default Re: 4g JDM Headlight installation help (Stony TSi)
oops i used my friends name to post b4, so the above post was post by me PDPHKS, hahaha
Old Oct 15, 2002 | 05:48 PM
satan_srv's Avatar
you coulda just got them off a Civic in a junkyard, or some other car that uses H4 lights
Old Oct 15, 2002 | 06:30 PM
ZoNe_HKS's Avatar
DAMN you right!!, i own a civic too, why didnt i think of that civics uses H4s too F**K F**K
Old Oct 16, 2002 | 07:48 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Here's the complete instalation guide... do a search next time, I just posted this. http://www.geocities.com/SP33DD3MON666/jdmlights.html
Old Oct 16, 2002 | 07:51 AM
satan_srv's Avatar
Sorry guy I guess I should mentioned it earlier....you made me laugh though
Old Oct 16, 2002 | 10:31 AM
armharm's Avatar
h4 bulbs have both high and low dont they? cant you just use the h4 for high and low and use the space where the USDM high is to put a fog light?
Old Oct 16, 2002 | 10:41 AM
satan_srv's Avatar
Yeah but you need to wire in a relay to make it work properly. Stock Prelude lights have high and low on at the same time cause they are in different housing/bulbs. You don't want both filaments on at the same time in an H4 bulb...dangerous
Old Oct 16, 2002 | 01:34 PM
armharm's Avatar
so how is it in japan then?
Old Oct 16, 2002 | 02:19 PM
satan_srv's Avatar
They don't even use one of the filaments. I proved it here http://www.preludeonline.com/showthr...threadid=88235
H4 = Low beam
H1 = HIgh Beam
Don't ask me why, that's just the way it is, the H4 high filament is not used
Old Oct 16, 2002 | 02:28 PM
armharm's Avatar
H4 = Low beam
H1 = HIgh Beam
oh.... so if u want fog lights u have to sacrifice ur high beams?
Old Oct 16, 2002 | 02:29 PM
BoostedH23a1's Avatar
what blub is better? 9006 or H4? is H4 the low beam? i have to have hibeams too. let me know they will be here tommorow someon please post that preludeonline one. its being jewish and not letting me in for some reason. even after i log in.
[Modified by BoostedH23a1, 6:36 PM 10/16/2002]
Old Oct 16, 2002 | 04:11 PM
ZoNe_HKS's Avatar
Default Re: 4g JDM Headlight installation help (BoostedH23a1)
umm i know theres a way to wire it so that h4 will have highbeam and low beam and u can control that in the car... and the h1 will jsut be a foglight to be controlled by a switch. thats what i am going to do.
Old Oct 16, 2002 | 04:35 PM
armharm's Avatar
cool.. once u get it done post a thread on what u did so i can follow suit...
Old Oct 16, 2002 | 04:41 PM
so i have to use the stock usdm bulbs to have high beams??
Old Oct 16, 2002 | 04:55 PM
satan_srv's Avatar
No you guys are not understanding what I'm saying....
Yes you could wire the H1s as "fogs" with a relay, but the fact of the matter is they are bright as **** and are not fog lights. They are high beams. Wiring the H4's for both highs and lows is a pain and if you want to do it go right ahead.
If the want the simple and true jdm way wire them the same as the USDM lights
9006 to H4 Harness
Red Lead (Low beam) = Top prong of H4
Black Lead (ground) = Left prong of H4 (Looking at back of bulb)
9005 to H1 harness
okay well these are both red with some other colour...but anyways just match them, one is ground, the other is the high beam lead. The JDM harnesses should have the same colour. Here's a pic for reference
Old Oct 16, 2002 | 05:09 PM
im more confused now then when i looked at this ahaha
Old Oct 16, 2002 | 05:28 PM
armharm's Avatar
u and me both buddy...
ok lets try something different here satansrv:
in japan the prelude headlights have H4 bulbs which have both high and low beams... in the center parts they have yellow fog lights... right? so what if i were to have the EXACT same japanese configuration with my headlights? is it possible?
Old Oct 16, 2002 | 05:37 PM
damnit i want mine just like it is now (usdm) no fog light buillsiht
Old Oct 16, 2002 | 05:51 PM
armharm's Avatar
but i dont...lol... good luck explaining satansrv..
