Charging system issues
Old Feb 11, 2012 | 02:47 PM
BombSquad91's Avatar
Default Charging system issues
I have a 1989 Civic DX Hatchback with the 1.5. Brought the alternator to Pepboys and it tested good. Bought a new battery. Put the alternator and new battery in. Drove to Pepboys again and had them test the alternator in the car. Tested good. Somehow the juice from the alternator isn't getting to the car. According to the voltage meter the voltage keeps dropping as I drive. I drive for half an hour and the voltage went from 11.5v to 10.7v. Then I pulled the positive terminal off the battery and the car shut off which it shouldn't do. AND the battery warning light is on. When I rev the car up the light goes off then comes back on when the rpm's drop.*Also all the fuses in the car are good. What's my next troubleshooting avenue? Thanks in advance.
Old Feb 11, 2012 | 07:39 PM
Default Re: Charging system issues
Took the whole engine wiring harness out of the vehicle. Checked every inch of the charging wire, all good. Ima put it back in and start the car with the charging wire disconnected and check the voltage at the alternator terminal. I checked it before but with the wire connected. It had the exact same voltage as the battery which makes sense. It was probably reading the battery voltage.
Old Feb 11, 2012 | 07:59 PM
90_EX_Civic's Avatar
it's probably your alt. one of the diodes/regulators in side might be faulty.
Old Feb 11, 2012 | 08:03 PM
That's what im thinking but Pepboys checked the alternator TWICE and said it was good. Could they have been wrong?
Old Feb 11, 2012 | 08:07 PM
KINGVEM^^ED6's Avatar
Check your grounds bro maybe.go to another store to get it.checked
Old Feb 11, 2012 | 08:11 PM
Checked all the grounds, good. Ima put my foot in someone's a$$ if the alternator is bad. They checked it out of the car AND in the car.
Old Feb 11, 2012 | 09:44 PM
Definitely the alternator. I disconnected the charging wire from the battery and put a voltmeter to the alternator terminal and it was only putting out 1.3 volts. Im sueing Pepboys.
Thanks for your input everyone.
Old Feb 12, 2012 | 03:37 AM
Lol
Old Feb 12, 2012 | 03:55 PM
n2xlr8n's Avatar
Sounds like my car. Same thing, 90 Civic DX.
I'm not a Honda guru, but I have been wrenching for 30 yrs or so.
I wound up putting new grounds from my engine to the chassis. I also found that the ECU wasn't fastened to the chassis I reseated the connector in the fuse box for the ELD (from what I understand, it's "electronic load detection"...honda's attempt at additional fuel efficiency).
Hasn't missed a beat since.
Old Feb 12, 2012 | 07:51 PM
they can check it as many times as they want, it'll always read good on their machine. you could go to any other parts store and they'll come up the same.
unless you take it to a garage and they hook your car up to a electrical load machine, it'll read good.
it's because your alternator just has a faulty diode/regulator. if only one is bad, you'll still have the other 5 or 7 (alternators usually have ether 6 or 8 diodes/regulators) which will still be able to read ok. there is a terminology for it, but i don't know what it's called.
meterus
Feb 10, 2011 03:00 AM
stockk
14
Aug 27, 2009 11:39 AM
sky88
Jul 17, 2004 11:30 AM
dualblade
Dec 10, 2003 04:20 PM
