EF IACV
I am trying to remove my ef iacv but i don't have enough room to remove the bolt on the bottom of the iacv it is too close to the engine bay wall do i have to remove the transmission or is there an easier way and the top bolt of the iacv doesn't want to loosen
http://s1060.photobucket.com/albums/t455/Efhatchback/
can you go to the link it doesn't load when i try to put it here
[IMG]<a href="http://s1060.photobucket.com/albums/t455/Efhatchback/?action=view&current=IMG_0134.jpg" target="_blank"><img src="http://i1060.photobucket.com/albums/t455/Efhatchback/IMG_0134.jpg" border="0" alt="Photobucket"></a>[/IMG]
Don't call me a noob i have a 85 orc dk with full season 10 you crooked nosed **** sucker, i tried using a wrench, i am turning it so hard the car leans to one side and it only turns a little bit, no matter how many times i do it, it still turns the same and doesn't feel like it is loosening, the bolt is starting to get round from all the twisting I'm doing so i know its not because i am a weak ***.
LMAO!!! Man I use a wrench every single time I take them off. Stop being a noob.
Theres not enough room for hands to fit and i can't ****ing pull the hoses apart i need more ****ing room my hands keep hitting all the **** in the engine bay and it ****ing hurts
How come my iacv is in a hard ****ing place to remove it, i need to wiggle the hoses out but i ****ing can't the hoses are short so i can't pull them out to get more room and my hands get ****ed up from trying to wiggle it from that tiny space i am moaning and groaning and my neibors are staring at me what the **** do i do?
I sprayed wd40 on the hoses but all it did was ****ing make it slippery what the **** do so i can get more room to work in is there a ****ing way to move it out from that ****ing small space **** my hands hurt
The pain in my hands is so ****ing unbearable, they are now generously lubricated in wd40 that is adding to the pain in my ****ing hands i'm about to break down and cry, thats how bad it hurts right now.
I got the hoses off, i used a chisel tipped screw driver to pull the 2 hoses out, when i pulled it out coolant gushed out onto my hands actually relieving the bruises and cuts on my hand for a short period of time, after that i cleaned the iacv, I have never experienced this kind of pain in my hand before and i hope i never have to go through this ****ing pain again. I am going to put the iacv back on tommorow and see if i am still getting code 9 from my ecu CHEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
I'm missing one lug nut but i don't give a ****
Last edited by Alanhino; Feb 11, 2012 at 10:46 PM. Reason: Why you asking me? I edit it cause i felt like it.
I had to look it up as well. haha! I'm trying to figure out if op is serious or if this thread is a not so good joke.
