bore n stroke?
Old Feb 11, 2012 | 09:05 AM
enriquez2000's Avatar
Default bore n stroke?
I have an f22b1. Im used to old Chevystrokers where u throw a 400 crank in a 350cents block. Do we have any options like that? What's the typical cost?
Old Feb 11, 2012 | 11:10 AM
GhostAccord's Avatar
Default Re: bore n stroke?
There are 100mm stroke kits available for around $2500. You might be able to piece one together cheaper. I looked into it a few years back and gave up. I ended up going with the stock 95mm stroke and going with an 89mm bore instead. Also not cheap!
Old Feb 11, 2012 | 11:56 AM
v4lu3s's Avatar
RTFM
buy an f23 overbore it and go from there. as far as longer stroke your f22 already has the longest stroke stock crank that fits in that block without extensive modification.
Old Feb 11, 2012 | 03:45 PM
chikin pickle's Avatar
Also offset grinding the crank and custom rods is a solution.
Old Feb 11, 2012 | 07:12 PM
Probably just go bizi cam.... Didn't think boring would cost so much...
pokie
11
Jun 20, 2010 07:23 PM
d16dcoe45
Oct 25, 2006 03:52 PM
Chugger
Mar 3, 2006 01:22 PM
K20 EG
Jun 24, 2003 09:22 AM
