Sqeaks In the Rear Hatch
Do you guys think the rear wiper motor is the cause of the sqeaks?
I only get squeaks from the rear side when I hit a pot-hole or man-hole.
Never from the right side.
What have you guys done to cure sqeaks?
Just took the wiper + motor out. It was a bitch getting off!!
Anyways almost all the squeaks I had before are now gone. It pretty much is the stupid motor sloshing around a bit over bumps.
Well to get rid of that noise that you have in the Back you open your trunk....then on both sides of the trunk you will see a black rubber stopper thing on both sides....you wanna unscrew it out a bit....TADa You have to put more force into shutting your hatch but its worth it
DETALZ
Jun 21, 2007 07:06 PM
Bigjon
Jul 14, 2002 07:49 PM
