snap-on blue point harmonic dampener part#ya6010a?
Old Feb 11, 2012 | 07:24 AM
949's Avatar
949
Default snap-on blue point harmonic dampener part#ya6010a?
i wanted to verify with you guys if this is the correct part to remove the harmonic balancer aka crank pulley on
2001 honda accord v6.
its a snap-pn blue point part #ya6010a
http://buy1.snapon.com/catalog/item....group_ID=12560
i know someone is going to say that there is cheaper versions out there.
so, my next question is.
i have read online that cheaper versions are a bit loose when used.
is this bluepoint snap on version closer to the oem honda tool in quality? or will it be loose like
Powerbuilt part #648796
http://www.catalyticconverterreviews...y-removal-tool
Old Feb 11, 2012 | 11:14 AM
GhostAccord's Avatar
Default Re: snap-on blue point harmonic dampener part#ya6010a?
I have used the Powerbuilt crank pulley tool many times. I have never noticed it being so loose that it would cause any problems.
Old Feb 11, 2012 | 07:25 PM
949's Avatar
949
what do you rate the quality of the powerbuilt?
Old Feb 12, 2012 | 06:39 AM
Not sure what to rate it against. I have never used anything else. However, if I had to rate it, I guess I would have to give it a 10/10. It has performed as required every time I have used it.
For the average DIY'er the price and quality is right. Now if you had to do 2-3 timing belts a week. You would probably be better off spending the money and buying it off the truck.
Old Feb 14, 2012 | 09:39 PM
949's Avatar
949
gotcha. thanks. with your advice ill go with power built because of the price and quality. i am only doing it on the personal car. so i may not req that i get an expensive high quality snapon piece.
Old Feb 15, 2012 | 08:46 PM
seanbev24's Avatar
The Blue Point tool is just rebranded with a price mark-up. The power built tool is fine, and probably from the same factory anyway.
THIS is the Snap-On tool for Honda crank bolts
http://buy1.snapon.com/catalog/item....e=&dir=catalog
kte324
Dec 1, 2009 11:16 PM
civicstar
Honda S2000
Mar 29, 2008 06:51 AM
slor209
Mar 12, 2008 01:02 PM
MyRex
Mar 28, 2006 05:54 PM
accord91lx
Dec 26, 2003 11:09 PM
