Over heated
Three months ago I replaced my 92 Accords radiater,thermostat and all hoses. All has been Great until last night. It overheated big time.
Any ideas for this to happen out of the blue??
Thanks
Thanks
Sorry, long list of items.
Did the stat stick, is there another leak, was it sitting still and the fans don't work.......I could keep going.
I guess your next step is to see if the head gasket is ok. Do you have a compression tester....or check coolant level, add and bleed if needed. Carnk it up and see what you have, and yes keep an eye on the temp and look for leaks.
