Master Cylinder Fittings
Old Feb 11, 2012 | 04:26 AM
wubanga's Avatar
Default Master Cylinder Fittings
Have an issue with the fittings off the brake line going into the master cylinder leaking. Is there anybody that knows what fittings and sizes I am supposed to use? Thank you
Old Feb 11, 2012 | 05:35 AM
TearSDMF89dx's Avatar
Default Re: Brake booster eliminator
what master cylinder are you using?
Old Feb 11, 2012 | 12:19 PM
wubanga's Avatar
Default Re: Master Cylinder Fittings
I am using the willwood master cylinder with the booster eliminator plate. Tried to T off the two brake lines into the master cylinder using the Teflon tape to try to seal it but it still leaks.
Old Feb 11, 2012 | 12:51 PM
another_aca's Avatar
You don't want to use teflon on brake lines. It will contaminate the fluid
Old Feb 11, 2012 | 03:41 PM
wubanga's Avatar
Ok what should I use to make that seal? Thank you for letting me know.
Old Feb 12, 2012 | 02:08 PM
Just look at the flairs if it ain't sealing. If they aren't cracked then you just need to tighten them more. That is as long as the fittings are the right size, but they will be if you are using stock parts on stock lines
Old Feb 13, 2012 | 04:51 AM
i thought the wilwood master uses sae 3/16" tube nuts for the fitting
Old Feb 13, 2012 | 07:12 AM
wubanga's Avatar
I will try to tighten them some more. Don't want to strip the nut end on that line so I was cautious when first tried to assemble it all. Thank guys will let you know how it went.
cpthaegdon
Jul 20, 2011 11:12 PM
alscrx
May 9, 2008 04:34 PM
Supra
Jul 6, 2005 08:48 PM
