Accord injectors not firing. Please help.
A little history, 97 accord ex 175000 miles. Timing belt broke and bent the valves in cylinder 4. Got new valves put in head, reinstalled head, new timing and balance shaft belts and now the injectors will not fire. I have 145-150 compression across all cylinders, good spark to all plugs, have triple checked timing and valve adjustments. Question is, is there a sneaky ground wire I could have missed when I hooked everything up? I have spent all day looking to no avail. Any help appreciated.
If it was the main G101 engine harness ground, as mentioned above, there would be no spark ether.
Make sure that the resistor box and injector connectors are plugged in tight and they are clean of debris. Also that they are getting battery voltage.
I pulled them fuel rail and watched nothing come out as engine was cranked. The problem was solved though, it was the ground that connects to the manifold. Thanks for the very helpful information
That's odd that you had spark to the cylinders in that case.
Oh well, Good to know that you were able to get the issue fixed with the info that you received.
95wagon
Aug 3, 2014 07:00 AM
Kike_Si
Dec 13, 2007 04:28 PM
