Cam Shafts for H23a1
Old Oct 9, 2002 | 02:25 PM
Xlerate9's Avatar
Default Cam Shafts for H23a1
Hey does anyone make cams for the H23a1? All the ones I find are only for the H22. Thanks
Old Oct 9, 2002 | 02:26 PM
PrecisionH23a's Avatar
Default Re: Cam Shafts for H23a1 (Xlerate9)
gude has them, but they are regrinds
Old Oct 9, 2002 | 03:35 PM
rybred's Avatar
This is the reason i'm swapping in a h22...parts are so much easier to come by!! Keeping my tranny though!
Old Oct 9, 2002 | 07:48 PM
user 9782082308's Avatar
Default Re: Cam Shafts for H23a1 (Rybrid)
Check out Web cams. They make regrinds as well as new ones.
Old Oct 9, 2002 | 07:50 PM
Cottonwoodz's Avatar
Why would you keep the tranny?
Old Oct 9, 2002 | 10:15 PM
rybred's Avatar
Default Re: Cam Shafts for H23a1 (Cottonwoodz)
Shorter gearing, isn't it?? Or is it the same for all 92-96vtec or non-vtec? 97 and up are different? I thought the si tranny is the one with the shorter gearing?? Well if all 92-96 are the same, then i guess i won't keep it, just get one with the engine!
Old Oct 10, 2002 | 01:40 AM
riceboy's Avatar
Rybrid , to the best of my knowledge, the tranny mounted to the H23 has shorter gears than the one mounted to the H22.
Xlerate9 , I also say to give Web a call, I used to have an H23 Lude, and the cams seem to be well designed from the factory, but they need a little more breathing from 5700-6500, where the piston speed starts getting to high for the head to have time to breathe. It would be nice if the engine could produce power up until 7000, for this I would think all that would be needed would be some cams from Web with slightly increased lift, and thats about it, plus without increasing duration, they would be good turbo cams should you choose to eventually go that route.
Silkk Tha Shocker!
Aug 26, 2006 04:25 AM
crj_lll
Aug 14, 2003 01:56 PM
rocket_R
Feb 20, 2003 05:52 PM
AndyD
Feb 18, 2003 10:35 PM
b18bEG
Sep 15, 2002 11:19 AM
