2002 Honda accord lx engine replaced HELP?
Old Feb 9, 2012 | 02:27 PM
zimmerman14's Avatar
Default 2002 Honda accord lx engine replaced HELP?
OK long story short had to replace my 2.3L in my 2002 Honda Accord so far so good trans was acting up so the place that put the motor in said to go to transmission shop (OMG) well they checked said all was fine just had a connector off it would not go into over drive or passing gear. OK the problem still now is the knock sensor error code keeps coming back I have replaced the sensor but still get the code error. this is the ULEV motor
Honda ID is #1hGCG32642A013358.
Do I need to do something different since I put a replacement motor in the car? wiring harness issue? please help pockets going empty only had car about month from used car lot ....................................
any way to test the sensor? or wiring harness to fix this
an sorry if I posted in wrong place I searched but couldn't find anything else about this
Old Feb 9, 2012 | 04:43 PM
ricebike's Avatar
Default Re: 2002 Honda accord lx engine replaced HELP?
check the wiring (should be simple to see if there's continuity from the sensor plug to the ecu)
Old Feb 12, 2012 | 07:38 PM
Thanks will have them do that soon as I get free time. What if that will not work any other thought?
Old Feb 12, 2012 | 10:41 PM
brianb242's Avatar
I had simular problem with a customers car, although it was a 96 civic lx, the engine was misfiring so badly it thru a knock sensor code, fixing the problem I changed the fuel filter,distributor cap and rotor, new plugs and wires.
Joseph Burrough
May 7, 2017 05:29 AM
Revenant_06
Aug 13, 2015 01:35 PM
wade9233
Jun 15, 2013 04:17 AM
wade9233
Jun 14, 2013 06:20 AM
JoshR172
Mar 19, 2005 05:26 PM
