hondata s300 full throttle shift help
Old Feb 9, 2012 | 01:27 PM
v.i.gsr's Avatar
Default hondata s300 full throttle shift help
Trying to figure out how to wire up my fts on my s300. I have a dx hatch that does not come with cruise control from the factory, so I bought a cruise control switch to make the fts option work in the s300.. Can I send 12v(switched) to one side of the cruise control switch, with ground from the other side of the cruise control switch going to the psp B8 pinout to the ecu ..
Old Feb 9, 2012 | 04:38 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: hondata s300 full throttle shift help
So what are you trying to do? Push the cruise button when you are trying to shift? Are you sure you understand how full throttle shift actually works? Most people just use the clutch switch...
Old Feb 9, 2012 | 05:38 PM
v.i.gsr's Avatar
Hondata suggests using the cruise control switch, that is located on lower portion of the clutch pedal, so that when the pedal is pushed in it releases the switch to cut the ignition and lower the rpm to a safe point that you can shift without lifting off of the throttle.. I understand how it works, I don't think you understood my question..
I already installed the cruise control switch in the location on the clutch assembly, just not getting it to work in the s300..
Old Feb 10, 2012 | 05:42 AM
v.i.gsr's Avatar
FIXED PROBLEM SOLVED....
Old Feb 10, 2012 | 07:13 AM
FlewByU352's Avatar
Could you explain how you did this? Did you directly wire the cruise control to an input or did you use the factory wiring? So you would need the switch on the panel, the clutch switch, and the little box for the cruise control interface or no?
Old Feb 10, 2012 | 10:52 AM
v.i.gsr's Avatar
No interface box needed for the s300.. I spliced into the clutch switch(the one that is used when starting the car)(blue wire 12v) to one side of the cruise control switch I bought, then ran a ground from the other pin to the B8 pin-out in the harness.. Then just enable the input in the s300 software. You may have to invert the signal in the software..
Just for your info, my clutch switch is bypassed so I no longer need to press in the pedal to start my car..
justinCO
Nov 14, 2008 09:52 PM
cehcivic15
Jul 18, 2008 04:27 PM
digital sol
Jul 27, 2006 05:15 PM
flip1199
Jun 18, 2003 07:02 AM
proton
Jul 9, 2002 11:13 AM
