f22 head work
Old Feb 9, 2012 | 09:31 AM
BigRex88's Avatar
Default f22 head work
Trying to find out what a good step up valve or valve's would be good without spending a lot of money, also need springs, circle track car running6-7k tons for 25-35 minutes a session
Old Feb 9, 2012 | 11:57 AM
mherkamp's Avatar
Default Re: f22 head work
Supertech?
Old Feb 9, 2012 | 12:03 PM
BergRacing21's Avatar
Originally Posted by mherkamp
Supertech?
Nope, Supertech doesn't make anything for the F22's. I called them to see if they did cause i'm in the process of building mine. The two i found were Bisimoto and KMS Engine Development they both make valves, guides, springs, and retainers for the F22A. I went with Bisi's cause he offers a 2mm over 1mm over option where as KMS only overs .5mm over on both
Old Feb 9, 2012 | 12:52 PM
mherkamp's Avatar
Or go with h23 head?
Old Feb 9, 2012 | 01:14 PM
lol that would work. He'd probably have more success with the H23 road racing than a F22 that's for sure. Only reason i'm building one is cause these things love boost and it's different.
Old Feb 9, 2012 | 01:32 PM
97ludedude's Avatar
if it is allowed in his class. depends on rules.
Old Feb 9, 2012 | 02:44 PM
InvaderTrax's Avatar
Quality valve springs don't come cheap. What cam will you be running?
Old Feb 10, 2012 | 01:37 PM
BigRex88's Avatar
I can only run a mild cam due to "stock" regulations, competition is running a non stock cam but we came prove without causing a big **** storm, we can only run a non vtec single cam in this class what kind of cam would be a good recommendation for this motor withour bringing a lot of attention
Old Feb 12, 2012 | 02:48 PM
mherkamp's Avatar
I talked to Delta abt regrinds for my h23, seems they are more popular in accord forums, ie f22. BTW they have several cam profiles, i think 252, 262, 272 or some such numbering. Give them a call, they regrind about anything and have made cams for old engines from scratch when needed.
GL
Mike
Old Feb 13, 2012 | 03:23 AM
BigRex88's Avatar
Thanks, u guys have been a big help in this build
just_stock
May 3, 2024 02:23 PM
racer034life
Dec 12, 2016 09:41 PM
91(si)hatchey
Dec 22, 2006 05:16 AM
ludesleep
Jun 3, 2003 01:41 AM
H23A1LUDE
May 14, 2003 03:10 PM
