Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help...How to take off speedo gear b16 hydro tranny
Old Feb 9, 2012 | 09:22 AM
eg714's Avatar
Default Help...How to take off speedo gear b16 hydro tranny
First time dealing with tranny. I have a stock b16 tranny and putting in a mfactory lsd. Already tore the tranny apart and I'm going to be reusing the stock diff ring gear and speedo gear except i have no clue how to take the speedo gear off the stock diff. Any help?
Old Feb 9, 2012 | 09:57 AM
Honda Bull's Avatar
Default Re: Help...How to take off speedo gear b16 hydro tranny
Puller.
Old Feb 9, 2012 | 12:06 PM
eg714's Avatar
Know where I can get one and which one will work the easiest?
Old Feb 10, 2012 | 11:44 AM
Honda Bull's Avatar
You don't have a local store that sells tools? Autozone. Advance Auto? Tractor Supply Co? Sears? You can purchase them online, too. You could pay a machinist to pull it off. A 2-jaw puller (or a 3-jaw that can be converted to a 2-jaw) will work best.
Old Feb 10, 2012 | 06:00 PM
MR.johnson's Avatar
i use a bearing puller and a little heat.
Old Feb 10, 2012 | 08:49 PM
jdm inc's Avatar
evans has a video on it! at about 40sec
http://www.youtube.com/watch?v=avTFN...feature=fvwrel
Old Feb 11, 2012 | 07:57 AM
Honda Bull's Avatar
Just don't follow his method of removing ring gear bolts. If the ring gear had shifted, you'll ruin every single one removing them one at a time the whole way out. Loosen each one a little at first, then you can pull them all out without damaging the actual threads that contact the diff.
Old Feb 11, 2012 | 09:13 AM
jdm inc's Avatar
^^good info!
Old Feb 16, 2012 | 05:53 PM
AaronDavis's Avatar
very carefully, doesnt take much to break. MR.johnson's got the key. I didnt heat my first one up and looked forever to find another after i broke mine. I heated it up putting it on too with some ATF on the mating surfaces. Good luck!
Old Feb 18, 2012 | 05:22 PM
Mista Bone's Avatar
D Tranny Guru
Large Bearing splitter turned upside down.
When putting it and diff bearings on, a STEEL pie pan placed on a electric plate or top of propane space heater.
LoneAutosport
Mar 15, 2010 04:39 PM
MrExclusive
Feb 4, 2010 07:52 AM
beastsohc
Jan 18, 2009 05:08 AM
BMo Tuning
Sep 13, 2005 11:25 AM
eg6turb0
14
Jan 9, 2005 10:07 AM
