SRS removal
Old Feb 9, 2012 | 08:55 AM
JDMEJ!'s Avatar
Default SRS removal
What's up everyone,
I'm pressing alone with my civic and had a question about the srs under the heater assmebly. Can I remove it plus all tye wires that connect to it since I'm currently using a non srs jdm steering wheel? Will removing it cause problems for the engine running the way it should or engine code on the ecu? ooo by the way I have a 1995 civic ex with b18c.
Here's a pic of what I'm talking about.
Old Feb 9, 2012 | 09:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: SRS removal
Leave it if you need to return it to stock later.
Old Feb 9, 2012 | 01:12 PM
phranky's Avatar
You can wire in a resistor and leave it, this allows you to keep the srs system active and use a aftermartket wheel and not have a SRS light.
Old Feb 9, 2012 | 01:18 PM
kaiba's Avatar
Removing the SRS unit or any of the component will not effect the car performance.
Old Feb 9, 2012 | 07:15 PM
JDMEJ!'s Avatar
Thanks everyone, I decided to remove it since it wasn't hooked up bc I have a jdm steering wheel. Glad it doesn't effect the motor running.
Old Sep 24, 2014 | 12:38 PM
chrismanis's Avatar
hate to bring up a dead thread did removing the srs unit turn the light on ? someone cut the cable reel to the steering wheel and i cant get my light off on my 92 civic hatch
niceprelude
Dec 11, 2008 05:05 AM
Rene M
Oct 11, 2006 02:43 PM
MEANB18
Dec 24, 2003 09:43 PM
Grimm
Aug 29, 2003 07:52 AM
