Del Sol - main bearing in S20 transmission going out
Old Feb 8, 2012 | 04:49 PM
Mr.F's Avatar
Default Del Sol - main bearing in S20 transmission going out
I just picked up a 95 Del Sol S. I love it and it is my new project car. My basic question is the main bearing in the S20 transmission is going out. It has a D15B7 that is stock and running strong for 187k on it. Should I pull the tranny and have it rebuilt, and put a D16z6 or y8 head on and mini me it. Or should I do a whole Engine and tranny swap to a D16z6?
Thanks
Old Feb 8, 2012 | 04:55 PM
94EG8's Avatar
Seagull Management
Default Re: Need help with a plan
Input shaft bearing on one of those is worth about $20, figure in another $5 or so for the seal that goes under it, do the labor yourself and you're only in it for $25 (there are a couple of other bearings in that that you should look at, but chances are you'll be well under $100.
Old Feb 8, 2012 | 04:57 PM
hannslebo's Avatar
Well what do you want from this car? Tons of power? Maybe a little pep and a nice oem/jdm look? I mean if its a project...and you're wanting any kind of pep/power you will need to rid of the B7! Z6/Y8 is a good SOHC...I'd rather just find a full swap rather than a mini-me...what about B series?
Old Feb 9, 2012 | 06:13 PM
Mr.F's Avatar
94EG8 Thanks I think that is what I will do with the trans if I stay D series. I did pick up a used S40 trans but then I learned the gear rations in the S20 are better so I rather just rebuild.
hannslebo I would like a B16 the issue is cost I can't find any decent priced B16's I keep finding D16Z6's rebuilt for $800.
Old Feb 9, 2012 | 06:48 PM
94EG8's Avatar
Seagull Management
It depends on which S20 and which S40 you've got. All S20 tells you is it's a '92 - '95 Civic/Del Sol D-series transmission, S40 just means '96 - '00 Civic/Del Sol D-series transmission. Check the stamp above the fill hole on the side of transmission. A000 = long geared CX/DX/LX/VX (there are actually two possibilities here, CX/VX = really long or DX/LX = still long but not as bad, finally you have B000 = short geared EX/Si transmission (if S20, if it's an S40 you have a possibility it could be an HX (big bearing case, but geared long))
I don't want this to turn into big flame fest or anything, but B16s are overrated, even in a CX hatch they're still torqueless, they don't feel any different than a Z6 until about 5000rpm. A B18C GS-R is a far better choice IMO.
Old Feb 21, 2012 | 07:21 PM
Mr.F's Avatar
I am putting off engine plans for now. Decided to build up the steering and front end. My plan now is to build from the ground up. Meaning suspension and steering first.
Kitsunami
Jan 25, 2016 01:35 PM
97dssi
Mar 27, 2011 12:34 PM
Its Stock I Swear
Aug 23, 2005 10:11 PM
shggy866
Jan 10, 2005 07:41 PM
