Nj: built gsr head, built ls block f/s!
Old Feb 8, 2012 | 02:10 PM
cuzimkenny1's Avatar
Icon6 Nj: built gsr head, built ls block f/s!
1998 gsr head for sale everything is brand new on this head 0 miles.
Supertech dual valve springs
Supertech ti-retainers
SPR-H100DR.
Brand new oem valve seals from honda
Skunk2 tuner2 cams
Skunk2 billet cam seal
Vtec solenoid brand new gasket
Brand new cam seals oem honda.
first gen. AEM trutime cam gears will come with it
Head has been milled .003
3 angle valve job
And 2 new intake valves
All work was done at a machine shop have recepits for everything.
It can also come with bnib skunk2 pro series intake mani comes with IACV, and IAT
Blox billet 68mm throttle body comes with tp and map.
Bnib black AEM fuel rail
Bnib black AEM fuel pressure reg.
no dizzy.
Take it all for 1200 slightly neg.
Now time for the block
Usdm itr pistons
Reconditioned ls rods with arp rod bolts
polished crankshaft with balenced rotating assembly
Acl rod/main bearings and,thrust washers
Has been deck .003
fresh hone
Assembled by the same machine shop, all clearences were in spec.
Have recepits for all work done.
I have an ls water pump/oil pump used not installed I will throw in since I do not need them
Rear main seal is brand new
I have oil pan gasket I will throw in too bnib from inlinefour
I do not have an oil pan
Oil pickup assembly is not installed but will come with the block
Vin:JHMDB7652YS001608
Asking 650 slightly neg.
call/text anytime at 6094562457
Old Feb 9, 2012 | 06:35 AM
ALLMOT0REJ1's Avatar
Default Re: Nj: built gsr head, built ls block f/s!
Would you sell the tuner 2 cams if so lmk how much
Old Feb 10, 2012 | 01:26 AM
Early morning bump..kinda need this stuff gone
Old Feb 13, 2012 | 06:09 AM
Rwdb16eghatch's Avatar
What's the. Best u will do on both head n block
Old Feb 13, 2012 | 06:22 AM
Txt me if u can I can't send u a pm cuz I'm a new member . 3618765430
Shane_00integra
Sep 19, 2012 01:44 PM
kelayala
Mar 22, 2012 05:56 PM
B16FlatBack
Feb 4, 2011 03:02 AM
91tegrsjg
12
Aug 29, 2010 05:48 AM
jdmef9gsr
Northern California (Sales)
Nov 18, 2007 12:13 PM
