88 crx engine problem
Old Feb 8, 2012 | 01:12 PM
robb88crx's Avatar
Default 88 crx engine problem
ive had this car trying to get it to run for some reason its not firing the timeing is fine new sparkplugs and cap and rotor tryed to spray either in the carb to see if its not getn gas and it still dosnt fire or even attemp to fire.. any ideas?
Old Feb 10, 2012 | 08:07 AM
sde780's Avatar
Default Re: 88 crx engine problem
Check your grounds, make sure starter is getting power/works.
Old Feb 10, 2012 | 10:48 AM
90civic-ZC's Avatar
Does it turn over? How did you check that you're not getting fire? If it turns over and you're not getting fire, check your coil and ignitor.
Old Feb 10, 2012 | 11:13 AM
Gremlin_rex's Avatar
Definatly the first thing to try. my coil fried a couple times along with the ignition control modual. Cheaper and better spark to go ahead and get the modified msd cap,rotor and external coil. Rather than replacing those pain in the *** peices. Was like 110.00 total. plus some 14 or 18 guage wire or w.e i got. Worked for me
Hooda_89'crx
Nov 11, 2010 10:34 PM
4thand5thgens
Aug 13, 2009 02:54 PM
themex77
11
May 9, 2007 04:54 PM
tigueremalo
Jan 23, 2007 06:42 AM
typeR00-0005
Jan 19, 2003 05:06 PM
