my maint. required light is on....how much to get car serviced?
Old Oct 9, 2002 | 01:14 PM
BlackAC99's Avatar
Default my maint. required light is on....how much to get car serviced?
my maint. required lite is on and i was wondering how much it is to get serviced at an acura dealer, i have a 1999 integra with 50k miles
Old Oct 9, 2002 | 01:18 PM
HeikDiesel's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (BlackAC99)
I say change your oil, plugs and air filter, and reach under the dash and push the little blue button . Right now might be a good time to do your timing belt also
Old Oct 9, 2002 | 03:06 PM
B18PoweredCivic's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (PhatAcuraIntegra)
I agree...Just give it a tune-up
Old Oct 10, 2002 | 01:07 PM
BlackAC99's Avatar
thank u so much, i didnt feel like spending that kind of money
Old Oct 10, 2002 | 01:24 PM
Audi A4's Avatar
good time for timing belt? no sir its to early for that. wait another 50 thousand. and just chance ur plugs ect fr now.
Old Oct 10, 2002 | 01:29 PM
au-gsr's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (DRAG lll INTEGRA)
Um reach under the dash hit the button and then throw some new spark plugs in there and then change your oil and filters-air -oil-fuel and you should be good to go, if you want to spend some money on your car right now would be a good time to get your fuel injectors professionally cleaned. the dealership will rape you if you take your car in every time that maintenance light comes on!!!!
Old Oct 10, 2002 | 02:30 PM
BlackAC99's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (au-gsr)
where do i get the fuel injectors cleaned and how much is it gonna be for that?
Old Oct 10, 2002 | 02:34 PM
Audi A4's Avatar
i wouldnt worry about the fuel injector either.
Old Oct 10, 2002 | 02:50 PM
SIK IN DA HED's Avatar
New User
Default Re: my maint. required light is on....how much to get car serviced? (B18PoweredCivic)
just press the reset button and waaalllllaaahhh!... the light is gone.
Old Oct 10, 2002 | 03:11 PM
Tomakit's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (dlplayboy)
If only all problems went away that easy .
Go buy chevron techron fuel system cleaner, that takes care of your injectors.
Buy some NGK copper plugs for your car.
Do an oil change.
Rotate your tires, and check pressures.
Check your airfilter. If its dirty, buy an AEM CAI, no sense in buying another oem paper filter. lol.
Push the little button under the dash, and you're set.
Tom
Old Oct 11, 2002 | 11:59 AM
BlackAC99's Avatar
Default Re: my maint. required light is on....how much to get car serviced? (Tomakit)
thanx that was alot of help, ill do all that this weekend
Old Oct 11, 2002 | 12:13 PM
GSRaCeRbOI's Avatar
50K is a bit too early for a timing belt change... not sure if the car was well maintained or if it had its 45K service interval/maintenance done...
since its used (I'm assuming its used since it has 50K and the maintenance required light seems new to you).. I would just replace a bunch of things to start off "new" from the time you got it... I'd do:
oil and filter change
valve adjustment
coolant flush
throw in a bottle of fuel system cleaner
spark plugs, cap and rotor
tranny fluid change
check brake pads, bleed brakes/change brake fluid
check the air filter..
check air and rotate tires (check brakes too)
fuel filter
might wanna check out your CV boots, belts/hoses, etc for cracks or any odd wear... check the battery, etc...
when your done reach up under the dash and push/hold the button...
a lot of these might not be needed if the previous owner took good care of the car.. but whenever my friend gets a "new" USED car.. he changes all the fluids and filters so it starts off "new" from the time he owned it...
Stopsign32v
Nov 20, 2010 07:51 PM
Bwoody
Feb 18, 2006 11:38 AM
SilentHill
Aug 15, 2005 03:37 PM
froger
Jun 3, 2005 08:58 PM
Seedc2
Aug 18, 2001 08:01 PM
