90 91 honda civic ef d series.
Old Feb 7, 2012 | 01:05 PM
RanCRX's Avatar
Default 90 91 honda civic ef d series.
My friends car recently has a problem. When he drives the car normally and the car reaches 30mph in second, when he shifts to 3rd gear the car shutsoff as if he turned it off, no noises. Then he can't start the car for a little while. But when it finally turns over it starts normally. It only happens when hes driving and switches to 3rd gear. I saw it a coupla weeks ago. It drives fine, sounds fine. But he only has water in the radiator.
My 2 guesses electrical or overheatin?
Any help appreciated thank u for ur time
Old Feb 7, 2012 | 02:06 PM
RanCRX's Avatar
Default Re: 90 91 honda civic ef d series.
I wish I could look at it but i'm back in my state.
It has been verified it's not overheating. Temp gauge works.
Old Feb 10, 2012 | 08:09 AM
sde780's Avatar
Main relay? Check for loose grounds
Old Feb 10, 2012 | 11:41 PM
Mr.crx si's Avatar
I think I know what the problem may be.Its the Throttle Position sensor.You cant buy them at parts stores at least not over here on the west coast.
They all say its dealer item only.The dealer will not just sell the sensor.it comes with the throttle body and you already know thats alot of money
I went on line and found one on ebay for like 15.00 i think at the most
But also Do what the other guy said about the relay and Ground wire too
maybe fuel filter is dirty.when was it last changed? if you dont know how long ago then it must be time
I hope this helps
mwaqas
Jul 21, 2015 07:15 AM
LuckyJDM
Oct 26, 2013 05:50 AM
NastySick
15
Oct 10, 2013 04:18 PM
mR BiBi
Jan 8, 2010 12:52 PM
91efhatch4lyfe
Feb 5, 2006 07:13 PM
