d15b7 with 4spd tranny, what clutch and flywheel? Searched!
Old Feb 7, 2012 | 11:18 AM
t-town_ep's Avatar
Default d15b7 with 4spd tranny, what clutch and flywheel? Searched!
I tried searching but couldnt get a solid answer. I plan on swapping a d15b7 (b7/z6) mini me into my 91 std hatch. i also plan on using the 4spd tranny. my question is, what clutch and flywheel will i have to use? i want to save money since its just a daily. is it possible for me to use the clutch/flywheel from the 4spd??
Old Feb 7, 2012 | 11:56 AM
90civic-ZC's Avatar
Default Re: d15b7 with 4spd tranny, what clutch and flywheel? Searched!
If you have the tranny out you can count the teeth on the shaft. Also on the tip there will either be no ring, one ring, or two rings......I cant remember what exact years but if I remember correctly 2 rings is 91+, one ring is 89 -90, and no ring is pre 89.......dont quote me but I believe that's how it is. My four speed had two rings and I cant remember the tooth count but I used a clutch and pressure plate from a 92 civic. As far as flywheels you'll have to make sure the diameter is correct for the clutch to grasp....and just count the teeth on the flywheel. Wish I could give you a more dominant answer but if it's already out the car it wouldnt take but five minutes to do all that.
Old Feb 7, 2012 | 12:01 PM
90civic-ZC's Avatar
I totally misread your post.....yes you can use the clutch, pressure plate, and flywheel from your four speed but just make sure you use the same starter ect.
Old Feb 7, 2012 | 01:46 PM
t-town_ep's Avatar
Just to clarify, I also use the same motor mounts as well correct??
And thanks man.
Old Feb 7, 2012 | 01:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yes, and post mount from the "EF".
Old Feb 7, 2012 | 02:25 PM
94EG8's Avatar
Seagull Management
What clutch you use depends entirely on the year of the transmission. You can simply use the clutch and flyweel from the 4 speed transmission if it's still in good shape.
See chart below for additional info:
Old Feb 7, 2012 | 06:10 PM
t-town_ep's Avatar
thanks for all the info, and i totally messed up, i meant d16y7, not the b7. does the same things still apply to the d16y7?
Old Feb 7, 2012 | 06:16 PM
94EG8's Avatar
Seagull Management
Yes, the clutch always goes with the transmission.
Old Feb 7, 2012 | 08:10 PM
t-town_ep's Avatar
And the y7 should use the same mounts as well correct?
Old Feb 8, 2012 | 05:23 AM
90civic-ZC's Avatar
Yes, keep and reuse the same tranny mounts......keep everything for the tranny including flywheel and reuse all of it.
Old Feb 8, 2012 | 06:17 AM
t-town_ep's Avatar
Thanks a lot man! You've been of great help
nitewolf
Nov 8, 2007 12:03 PM
pinecone
Jun 22, 2006 05:27 PM
honcrx91si
Aug 14, 2005 08:56 PM
crxb20ed
Aug 14, 2004 11:52 AM
Donkey85
Jul 27, 2004 03:24 PM
