sway bar question.
so i picked up a type R rear sway bar for my eg hatch and i need to get end links for it but i cant find what im lookin for. also i need to get the bushings for where the front sway bar attaches on a gsr set up. any help would be great! thanks!
http://www.jhpusa.com/store/pc/viewP...7&idcategory=0
These are the end links you need. I'm actually in the same process as you of getting a ITR bar haha!
Not to mention, if he does use thoughs he will need to buy spacers for the endlink bolts. The ITR holes are larger, and the bolts wont work.
OP, I am almost 100% sure you can use OEM endlinks.
Ahh I didn't know that. My bad. OEM ITR endlinks are hard to find though.
For the GS-R you can get front sway bar bushings from a dealer. Actually you might want to just get an entire endlink assembly.
IDK about EGs but the rear endlink on my GS-R mounted fine on my ITR sway bar with no modification needed that I can recall. Can you get some GS-R rear endlinks? I would guess they would mount on your LCAs just fine.
But the endlinks, (which I have) are total and complete trash. They failed in about a year.
Go to the dealer for those.
I remember reading somewhere the GSR/ITR rear endlinks were the same. It would be worth it to do a little research on that though.
Not you're fault, man. Most people don't know about the sway bar holes, until after they've already bought it/ and endlinks. lol That is how I know.
If you're talking to me, yes I have a Honda dealer like 15 minutes from my house. But from what I heard they can't order acura parts. The way to get around it is to just tell them the part numbers you need and they'll get it.
I heard the oem endlinks work too.. Wasnt sure but im gonna try that. I guess goin to honda and gettin the stuff frome them will ne my best bet. Thanks!
igo4bmx
Suspension & Brakes
Mar 18, 2006 10:12 PM
dgdarien
10
Mar 30, 2003 01:09 PM
