Help: AEM 30-1000/Nitrous stops working after key off
I have a weird issue with nitrous control.
Honda 30-1000 EMS
switch 3 gnd On
LS8 output
Nitrous works fine if I set it. I can unplug the laptop and it continues to work. Once I turn ignition off and back on (ie: parking car)
it will not turn nitrous back on.
If I plug the laptop back in all the settings are unchanged but only if I make a change in the nitrous parameters (any change) and hit ENTER it continues to work till I shut ignition off again.
any ideas?
Honda 30-1000 EMS
switch 3 gnd On
LS8 output
any ideas?
FIXED: Checked configure outputs tab, realized Switch 3 was also used for a different function which I do not use. I unassigned it and all is well now.
TurboT
Nov 9, 2003 04:50 PM
integraautox
Jun 2, 2003 08:04 AM
