will the og oldskools fit without rolled fenders
Old Feb 5, 2012 | 02:09 PM
cehcivic15's Avatar
Default will the og oldskools fit without rolled fenders
95 civic with progress coilovers. will the og oldskool wheels fit without rolled fenders. i have the buddyclub upper control arms but i want my camber to be correct and not crazy. they will be wrapped with 225/45 15 which gives an overall height right at 23". i would like to put 195/45 15 on but i dont know if the tire would be wide enough (no stretched tires)
if they wont fit ill prolly go with drag dr20
Old Feb 5, 2012 | 07:35 PM
toyomatt84's Avatar
Sanji
Default Re: will the og oldskools fit without rolled fenders
What size are the wheels?
Old Feb 5, 2012 | 07:50 PM
cehcivic15's Avatar
the only ones i have found are 15x8 +35
Old Feb 6, 2012 | 07:17 PM
cehcivic15's Avatar
c'mon i know tons of ppl have them. what mods are needed for them to fit and not rub
Old Feb 6, 2012 | 08:32 PM
toyomatt84's Avatar
Sanji
You will need to roll your fenders/quarter panels, and run a tiny bit of negative camber to clear the 225's in most conditions.
Old Feb 6, 2012 | 08:44 PM
cehcivic15's Avatar
would the 195/45 15 give it more clearance and would that tire be safe on that wheel?
Old Feb 7, 2012 | 03:44 AM
toyomatt84's Avatar
Sanji
Would it give more clearance? Yes.
Would it fit properly on the wheel? No. The widest wheel that those tires are rated for are 7.5" wide. Also, remember the car dictates the tire size more so then the wheel.
Old Feb 9, 2012 | 12:36 PM
doc@tirerack's Avatar
even at stock ride height we'd recommend a fender lip roll and negative camber to get them to work.....
chrisnick
Aug 11, 2013 03:40 PM
em2crusin
Apr 10, 2012 03:24 PM
jdmchickx
Jan 5, 2012 03:12 PM
gSrTEG&91hatch
Apr 16, 2011 03:48 AM
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
