Suspension & Brakes Theory, alignment, spring rates....
Ride height changing on Tein coilovers
Old Feb 5, 2012 | 10:13 AM
b_ron's Avatar
Default Ride height changing on Tein coilovers
I posted this in another forum but thought I'd see what h-t has to say.
I have tein basics on my ep3 (installed them late november 2011). After getting the ride heights all figured out, I drove it around for a couple days as is for everything to settle. I took it to firestone and got my alignment.
Ever since, the rear passenger side and the driver side would switch off being higher than the other. I'd say roughly 1/8" to 1/16" difference. Some day my finger will stop at the middle knuckle, other days it'll stop at my finger nail.
It'll keep switching sides. This, throwing off my alignment, gives me (what I believe) choppy tire wear in the rear.
Tein said it couldn't be the small crack in the bushings on the rear shocks (which I told them about).
The shocks arent blown.
Doubt its fatigue from springs
What could it be? Possibly some bushings that are worn out somewhere?
(I want to get this sorted out before getting new wheels/tires)
Thanks,
Brian
Old Feb 5, 2012 | 03:18 PM
bnetkillzone's Avatar
Default Re: Ride height changing on Tein coilovers
Post up the alignment print out. Does everything look fine?
Old Feb 5, 2012 | 07:21 PM
b_ron's Avatar
Rear Left alignment:
Before: -0.8 camber (specified range -1.6 to -0.1), 0.34 toe (specified range 0.04 to 0.16)
After: -0.7 camber, 0.07 toe
Rear Right alignment:
Before: -1.7 camber, 0.42 toe
After: -1.6 camber, 0.11 toe
they did make it within the range of the factory specs i guess, but still not as close as i thought they would make it.
Old Feb 6, 2012 | 12:16 PM
jdmjerry12's Avatar
do you have aftermarket kit
Old Feb 6, 2012 | 05:29 PM
b_ron's Avatar
aftermarket bushings?
my car is all stock except for the coilovers and rear camber kit
Old Feb 6, 2012 | 06:08 PM
jdmjerry12's Avatar
are you getting it checked to confirm that the camber/toe is moving.. it should not be as long as everything underneath is tight? bottom line is if the car is lowered and has stiff coils on it.. tires will not wear perfect. this is from my experience.. also those specific tires you have on the car i forgot the name of them, i have never seen wear good on any car stay away from that read pattern
Old Feb 6, 2012 | 08:19 PM
b_ron's Avatar
i'll probably have to get the alignment checked to see how much it changed from the first alignment then.
everything was tight when it was installed. not sure what could've loosened for the height to keep shifting
Old Feb 7, 2012 | 09:21 AM
Alignment specs look good, just rotate your tires more often.
Old Feb 7, 2012 | 10:58 AM
jdmjerry12's Avatar
what he said^
this will also help
Old Feb 7, 2012 | 06:02 PM
b_ron's Avatar
one shop told me to get the tire wear problem fixed first before getting my tires rotated..
i think i'd trust h-t more than some mechanics out there.
i'll have to check my alignment again to see any changes and get my tires rotated. not sure if it'll change the ride height change but maybe the choppy tire wear?
Ahknodd
Suspension & Brakes
May 9, 2009 05:59 AM
951dc5
Mar 30, 2008 07:44 AM
98b18black
Feb 17, 2006 09:36 PM
brian2903
Apr 28, 2005 07:33 AM
Katman
Oct 23, 2001 07:03 AM
