jdm d16a what crank sensor pulley
Old Feb 3, 2012 | 08:38 PM
roycivic92's Avatar
Default jdm d16a what crank sensor pulley
hey fellas i just got a jdm d16a to replace my non vtec sohc in my ek...the only problem i have is that the bottom pulley has no teeth for the crank position sensor.. and my original pulley is to small......any help would be help full.
Old Feb 4, 2012 | 06:54 AM
Former User's Avatar
Default Re: jdm d16a what crank sensor pulley
What ECU are you planning to run with the d16a?
Just informational: The sensor you are referring to is called the crankshaft fluctuation (CKF) sensor. The crank position (CKP) sensor is located inside the distributor.
Old Feb 4, 2012 | 10:01 AM
94EG8's Avatar
Seagull Management
The easiest thing to do is just perform the CKF trick to fool the ECU into thinking the CKF sensor is there and working. Otherwise you also need to swap the oil pump for an OBD2 D-series pump that has provision to mount the CKF sensor.
CKF trick -> http://technet.ff-squad.com/ckftrick.htm
Old Feb 5, 2012 | 09:33 PM
roycivic92's Avatar
hey thanks guys ..im using the oem us computer. so most likely im going to do the ckf sensor trick.....thanks for the link....
jjmcmana
Nov 1, 2008 09:02 AM
pokmijn
Jan 7, 2008 05:47 AM
