DA rear LCA on EF civic.
Old Feb 2, 2012 | 05:10 PM
SleeiNESS's Avatar
Default DA rear LCA on EF civic.
I did the rear disc swap a few months ago and encountering the negative camber everyone has been talking about. My question is if I am using DA rear LCA and getting negative camber...couldnt I switch out the EF rear UCA with a DA rear UCA to correct it a little? I just installed ES master bushing set and would hate to have to buy new sets for EF lcas.
Old Feb 2, 2012 | 07:05 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: DA rear LCA on EF civic.
I don't think the lca's and uca's are different however the toe arms are. Why dont you just buy a camber kit they are about $100 for blox on ebay
Old Feb 2, 2012 | 08:16 PM
Mr.Cheezil's Avatar
The only arm that you should have used from the integra was the trailing arm. Without EF lower control arms, you will never get the right alignment.
Old Feb 3, 2012 | 12:54 AM
CrazyFNG's Avatar
Rear lowers are the same, I agree with tcooper pick up rear camber kit from blox to fix the issue. I got mine for 110 new
Old Feb 3, 2012 | 02:48 AM
galbal's Avatar
read this:
http://ef-honda.com/ben/EFhybridsus.php
...has all the info u need!
Old Feb 3, 2012 | 06:27 PM
SleeiNESS's Avatar
Thank you all for the responses, the link explained a whole lot.
Old Feb 4, 2012 | 06:21 AM
alex14's Avatar
DA LCA's will not work properly. I have personally tried it and it gives crazy amounts of negative camber.
Old Feb 4, 2012 | 08:22 AM
KINGVEM^^ED6's Avatar
Rear washer trick ftw
Old Feb 4, 2012 | 08:30 AM
wreckin-rex91's Avatar
hahahahaha! I love it. Cheap and effective... Rockin the washers on my daily EG sedan. If you don't want baller status, washer work great.
I also swapped DA rear discs on my CRX, I had to us EF toe adjustment arms as the DA's are longer. Also I swapped in some F&F LCA's but the LCA's from EF to DA should work. I know lots of peeps that put the DA arms on so they can run a DA sway bar on their EF's. Google it
sde780
41
Jan 8, 2012 08:46 AM
CRXREFIC
15
Nov 8, 2010 06:31 AM
JDMchucko
11
Oct 25, 2010 04:43 PM
Projekt_Ef9
Feb 7, 2010 08:48 AM
91Hatcher
Dec 25, 2008 11:29 PM
