Input shaft bearing
Old Feb 2, 2012 | 03:31 PM
ThiRteeN's Avatar
Default Input shaft bearing
The bearing race was destroyed and the inner ring fell out. Anyone know how to get the outter ring out? Can't find an answer anywhere.
Old Feb 2, 2012 | 05:19 PM
94EG8's Avatar
Seagull Management
Default Re: Input shaft bearing
If you have a welder weld something to the race so you can beat it out from behind, otherwise you have a fun job of prying it out of there a millimeter at a time.
Old Feb 2, 2012 | 07:42 PM
pityocamptes's Avatar
Easy - take a rag and stuff it down the hole so you don't get metal all over. Buy, borrow, or etc a dremel with a small metal cutting wheel. Cut a "V" or similar 99% of the way through the ring on both sides - 180 degrees opposite of each other. Once you have cut almost all the way through - take a VERY SHARP small cold chisel and break the remaining 1% of the metal holding the race together. Do this on both sides and the pieces will come out in two parts. Hope that helps...
Old Feb 3, 2012 | 04:27 AM
hondamark35's Avatar
i had a similar thought of cutting the race out.
if the OP doesn't have a steady hand though, he could try reassembling the bearing (put the ***** back in and drop the inner ring back in) then space the ***** as evenly as possible and cram some bits of paper towel or whatever to keep the ***** spaced. then press out with the inner ring as normal.
Old Feb 3, 2012 | 03:29 PM
ThiRteeN's Avatar
Hondamark, thats funny you said that about the paper towels because I had the same idea after I got off here. Definitely worked out.
ldyer1994
Apr 23, 2015 08:19 AM
Nick97hatch
Transmission & Drivetrain
Jul 17, 2009 09:13 PM
ogmudbone
Feb 25, 2009 09:54 AM
jweller
Suspension & Brakes
10
Jan 29, 2008 03:06 PM
Surewin
Mar 2, 2005 01:26 PM
