96 Civic EX - cut Yel/Blk wire
ok. so i bought a 96 civic ex from a guy recently
the d16y8 motor was replaced with a y7 motor
i had a CEL so my first thought was maybe it still had the p2p(y8 ecu) in.
i was correct. so i bought a p2e(y7 ecu) and it didnt fix the problem. and yes, i made sure it was from a 96-98 civic w/ 5 speed trans.
also noticed the y8 harness was still in cause there are a few plugs up under the engine that have nowhere to go. understandable considering its a y7, so it doesnt have a vtec solenoid to plug into. so i finally called a friend and he came by with his obd2 code reader. it wouldnt link to my car. but heres whats puzzling me. when i replaced the ecu, i noticed one of the wires on the one the connectors was cut...the wire is yellow with a black stripe...maybe a different dark color.
could this be the issue??? anyone know where i can find a diagram for the harness to ecu or kno what the wire is?
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
What problem are you having???
alright...so your link helped out alot. i now know whats throwing the cel.
it turned out to be my IACV.
would i need to replace it or just take it off and clean it thoroughly??
fordmike1980
May 30, 2018 06:09 PM
