Differences/1.6 EL and 98 DX sedan?
Are there any superior suspension components that will swap easily from a 1.6 el onto my dx sedan?Springs?Struts?Anti Roll bar? I don't even have a rear roll bar,can i swap it with ease?
Are the brakes from an EL beefier than the dx's? Swappable?
yeah, swap the rear sway bar to ur dx
el has a stock 13mm one
also use the stock 1.6el rotors, they are sir/integra rotors
i've also heard the el shox are valved abit stiffer than civics, but even if it's true
probably not by much thou
other than that, not much worth swapping.
Can the front brake calipers and rotors be swappedas well?Or are they the same size?
Can I also swap the front EL sway bars onto my dx?
[Modified by bw54867, 4:02 AM 10/10/2002]
i'm pretty sure both calipers n rotors can be swapped
but not sure if u want to swap the front sway bar
what size is the dx bar
el is 24mm or 22mm, but quite sure
*Boostwerks*
Nov 15, 2006 09:22 PM
MBDiagMan
Oct 27, 2004 11:12 AM
