low or high pressure
hi
I have 1000 cc bosch ev14 injectors (at 58psi)
At either 45 psi or 58 psi, the injectors are more than enough for my setup.
What base pressure do you recommend me to use them on my ls/vtec and why ?
Thanks..
Thanks..
I would use OEM pressure specs for a gsr. which i believe is 43psi, so 45 is fine...i believe 50-55 psi at WOT. but at idle stick with 43-45psi. There is no need to turn up fuel pressure to get more fuel. Since you said yourself the injectors are more then enough for youre set-up so more fuel should be given thru the Tune, not thru higher fuel pressure. usually higher pressure is used when you are running out of injector and need to increase the amount of fuel given without going past the maximum recommended duty cycle on the injector
the.hamburglar
Mar 27, 2015 07:58 AM
injector experts please enter-injectors sizing for HP goals and fuel pressure and how they are relat
BlueShadow
Dec 9, 2005 11:11 AM
