5 lug setup question for a eg
Old Jan 31, 2012 | 09:31 PM
kid_02131's Avatar
Icon2 5 lug setup question for a eg
ok ive search google an ive read alot of forms some have good pics other have broken links ok all i like to know will the type r hub fit on the eg spindel, I seen a link an it talk about the rear is a basic bolt on but not sure about the front just need help on this thanks
Old Jan 31, 2012 | 11:53 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 5 lug setup question for a eg
You usually just use the whole spindle...and that works great.
You're trying to press just the ITR hub into the EG spindle? Well the "EG" came with couple different spindles. Year, model, front brake size, and the presence of ABS are all factors in answering your question.
You can find out if the part numbers are the same at www.bernardiparts.com for the spindles. Go from there.
Old Feb 1, 2012 | 09:23 AM
kid_02131's Avatar
my car is a 93 ex coupe an i heard that the spindle from the type r are diffrent an wil cause postive camber
Old Feb 1, 2012 | 09:24 AM
glennsek9's Avatar
I would just change the whole thing out, save you a lot of time.
Old Feb 1, 2012 | 09:26 AM
kaiba's Avatar
R wheel bearing are larger.
Old Feb 1, 2012 | 10:07 AM
kid_02131's Avatar
that i dnt know if the r bearing are bigger are they is thats how its Done just throw the whole spindel in
Old Feb 1, 2012 | 01:20 PM
B serious's Avatar
No, the ITR spindle won't cause positive camber on your 93 EX. If you used a CTR spindle, you'd have to do an alignment because the toe would be out quite a bit. But that's an easy fix.
Old Feb 1, 2012 | 01:26 PM
kid_02131's Avatar
ok well with this info im going to try to do a 5 lug on my 91 si cuz i have a eg
Ex suspension on it with camber kit an its a true camber
hymn
Suspension & Brakes
Feb 18, 2014 06:08 AM
NorthstaR
May 1, 2006 01:27 AM
lv6l
Feb 22, 2006 12:49 AM
doobiesack23
Jan 16, 2005 06:42 AM
