Car Overheating, Fan not working... Help!
Old Jan 31, 2012 | 04:24 PM
EscoSi's Avatar
Default Car Overheating, Fan not working... Help!
Yesterday my Si overheated. Checks revealed that the fan wasn't coming on. Tried to bridge the fan switch (paper clip or copper wire method). Still nothing. Ran a wire from the connector right by the fan to the battery and it came on. I would think the fan switch is dead in this case right?
Old Jan 31, 2012 | 04:42 PM
hannslebo's Avatar
Default Re: Car Overheating, Fan not working... Help!
Assuming you checked BOTH fuses?
Old Jan 31, 2012 | 04:49 PM
EscoSi's Avatar
Yes I did.
Old Jan 31, 2012 | 04:53 PM
hannslebo's Avatar
If the the "jumping" method didn't work with the paper clip...I don't think it would be the fan switch. Someone correct me if I'm wrong. Either way...you can replace it anyways...they are only like 10 bucks.
Old Jan 31, 2012 | 06:32 PM
accord2civic2prelude's Avatar
or just run a switch from inside the cabin directly to your fan. do it on all of my cars, like second nature now.
Old Jan 31, 2012 | 06:52 PM
hondaon18's's Avatar
Check to see if ur thermostatnis working . Usually when it gets stuck it makes ur car over heat
Old Feb 1, 2012 | 06:24 AM
motegicivic's Avatar
If you jumped the connector, then you have a fuse, relay or wiring issue.
Check fuses and relay first. Also check the fan itself see if the wiring is ok, maybe cut etc.
Also, when you jumped it, did you turn the key to the number 2.
Si joey
Oct 21, 2015 09:39 PM
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
joebmx
Oct 6, 2008 10:56 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
goldito187
Oct 30, 2003 11:18 AM
